- May 23, 2015
- 25,704
- Plaster
- Pentair Intellichlor IC-60
There is no need for a check valve before the SWG. That was done because the installer was used to installing tablet feeders where acidic water from the feeder could potentially backfkow into the heater and cause damage. SWG’s only produce chlorine when the pump is running and so there is zero chance of “chemicals” back-flowing into the heater....as you so aptly put it, that’s just more numbskullery to deal with.
Do note that most pool heater equipment manufacturers require that check valve for warranty compliance even though it is totally useless. So if you’re worried about maintaining warranty compliance, leave it in.
