Project in SE PA, bought a foreclosure w A&S pool
kimkats
42,123
Tallahassee, FL
How did they get the mucky muck out?? What ever you put that stuff on will grow wild and big I bet!!!
Where the snakes alive? Did they even try to save the tadpoles and frogs?
We had one clean out that had a dead deer in it :shock: then another that was a full grown pond with cattails and such growing in it! They had turtles as well and frogs and snakes! FUN times------------NOT LOL
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Getting so close! Drain and clean completed. Water will be delivered tomorrow am and Saturday will be the plumbing and opening of the pool. Tried to get them to do the plumbing first but they just wouldn't budge on their schedule.
Reactions: kimdurg and Burfcr
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Good news, bad news.
Good news- water delivered today
Bad news- since the plumbing was not fixed first there is a leak by the equipment. Lost about 10" of water right out of the broken pipes by the "endless pool" thingy. Guess the plugs in the wall of the pool weren't completely able to stop the water from exiting.
They are coming back tomorrow am to fix the plumbing, etc. Water level is below the skimmer so if they are able to open the pool it will have to be pulling from the floor drains.
kimkats
42,123
Tallahassee, FL
DOH!! You tried to tell them!! GURRRRRRRRRRR! Will they pay for the "lost" water?
That is a pretty color of water right there!
Do you a water test kit yet? If not look in my siggy for the one I think is the best bang for the buck.
Kim:kim:
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Total of 3 broken pipes caused by the down tree. Had to drain 1/2 of the water out to fix everything correctly. It's up and running now pulling off of the drain and the waterfall works perfectly. They are waiting on 2 4" fittings for the endless pool piping and then we should be up and running 100%. Water will be delivered (again) by no later than Wednesday.
It does need an old school manual vacuuming from all of the acid wash and power washing which they said I'm responsible for doing?? So I paid for a drain and clean, fill up, fixing the plumbing and a "bronze star" opening package and they won't spend an extra 15 minutes vacuuming the bottom of pool from the mess they made? Someone should really start an ethical, professional and reasonably priced pool service company.
Gorilla83
428
Thornton, PA
Progress, and great news! I hear you on the levels of "service" that are common - I've had the same experience across the board. That's fantastic that you're close to up and running though.
Edit: Get yourself a robot bro! No vacuuming needed :)
Reactions: strutaway
kimkats
42,123
Tallahassee, FL
You can't do a manual vacuum without a working skimmer. I am guessing yours is not working due to low water which is, again, THEIR fault :roll: Yeah pool people.............you should have fixed the PIPES that take the water to and from the pool and equipment BEFORE you put the water in!!! DUH!!
Oh well at least you can see just how pretty your pool can be. It will only get better as the water is where it should be and all cleaned up.
Did you get a test kit? How are you adding chlorine to your water now?
Kim:kim:
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Making progress day at a time. Plumbing fixed except the endless pool feature. This company does not have any experience nor have they seen one before. They capped off the 4" pipes so water doesn't escape but have everything else up and running. Waiting on a part for the heater and that could be it for now. Stopped by today and it looks and sounds like the pump has lost prime as about 1/2 of the pump/basket is filled up. Not sure how or why this happened because it's only pulling from the drains.
Pool company coming back tomorrow to finish the opening process, vacuuming the bottom, adding the chemicals and making sure everything is functioning OK.
They also started on the steps from the deck to the ground level. I'm away till Sunday but can't wait to see the progress when I return!
Reactions: Gorilla83
kimkats
42,123
Tallahassee, FL
I wonder if the system needs to be purged of air??? Or if it is sucking air. The o-rings might need to be lubed to stop air leaks. Just some ideas.
Kim:kim:
Gorilla83
428
Thornton, PA
If you decide to get a robot for cleaning (recommended) , FYI Maytronics/Dolphin promotions and rebates start again May 1st. I plan on ordering mine exactly on the 1st, haha.
Looking good though, lots of progress so far.
Reactions: Captchaos
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Ok, I'm back. Computer decided to die for a while. As far as construction not much has happened. Stairs coming off of the deck have started and thats about it as of now. Waiting on final prices for kitchen cabinets because we are about 2x over the builders allowance in that dept. Lucked out and found floor models for the range and refrigerator. Once we finalize the cabinets it'll be full speed ahead.
Onto the pool...had it all cleaned, balanced and looking really good. Even have the heater working and aside from all the weeds it is looking pretty good back there. Then comes the rains and a few "minor" issues with what we were told was the retaining wall not having a screen and letting all the dirty water pass through.
Lets start with me being all proud of how everything is looking. Check out the progress on the pool!
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Fast forward to Monday and I go to check out the house and pool because of all the rain. Here I am thinking it'll need to be shocked because of the rain water, maybe even the pool as overflowed a tiny bit on to the pavers.
I walk around the corner and see this.....
  • Wow
Reactions: kimdurg
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Our GC says "I'm 100% confident this is fixable. There is no screening behind the wall and all the dirt is passing through." Not sure I completely buy this because then it would be less dirty water pouring into the pool, etc.
I'm standing there at in the driveway looking at all the water pooling up and running right down the walkway, through the wall and dumping into the pool. Figured I'll try and dig a trench so the water will go around the walkway. Grab a rake, take one big pull across the wet, muddy grass and my god, there is a huge drain right there that was completely covered up. Literally with one pull of the rake the drain was exposed and all the water from the driveway started dumping into the drain which has a pipe dumping all the water into the woods. Problem solved and I'm a hero. A slightly upset hero that wonders why the GC didn't look around when he was there looking at the drainage.
About 8 days of backwashing 2x a day with the pump running 24/7 and the pool is Dang near perfect again. Except the Polaris stopped moving and I found a new leak in the pipes leading to the waterfall. Minor stuff in the grand scheme of things. Kids want to go swimming and it's reading 67*. Maybe next weekend.....
Reactions: kimdurg
