Project in SE PA, bought a foreclosure w A&S pool
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Not much info on this other than the house has been vacant for close to 4 years. Looks like an Anthony & Sylvan pool with a stone waterfall but no spa. Lets hope the shell is OK and it just needs new equipment.
I'm sure the water will need to be drained, etc. Hope to be a ready by spring. Fun times ahead!
ajw22
10,536
Northern NJ
Congratulations on your newly acquired project. We are here to help as you figure out what needs to be done.
There have been some great stories here about pools raised from the dead. Anything is possible with enough money or sweat.
kimkats
41,329
Tallahassee, FL
I am in on this one! Like Allen said any thing can be done with enough sweat or wallet!
When do you close on the house? Is there much work to be done inside the house?
We also bought a foreclosed house/property/pool. Took care of the house first then worked on the property THEN the pool. Ended up the pool was the easiest LOL
Kim:kim:
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Went to settlement last Thursday so the house is ours. There is a huge tree that fell right by the pool equipment that missed all the important stuff and only took out the PVC plumbing. Who knows if anything works but somehow the pool will be up and running for summer unless there are major issues. Seems to be holding water so hopefully no terrible cracks.
Might be crazy but have to ask it anyway.....can an attached spa added? I know everything is possible and its only limited by money. But seriously, if it's not too expensive would it be possible to add a raised spa?
House needs a ton of work, literally every room will be a redo. It'll be like new construction when we are finished. Plan to move in as soon as school ends with a functioning pool. What fun would that be to move in but not have the pool working?
Also thinking of adding a full court basketball court while we are at it.
Reactions: Teen124
kimkats
41,329
Tallahassee, FL
You could add a spa BUT I will tell you a stand alone spa is much better in that it is oh so comfy and has jets in all of the right places. You could have it right by the pool so the pool and spa people can hop back and forth as well as chat.
Do you have any clue how deep the pool is?
Kim:kim:
ajw22
10,536
Northern NJ
There are pool renovation threads of folks adding a spa to their pool. It requires an extensive renovation with new plumbing, tile, and plaster. If your pool end up needing it then it is a possibility.
A standalone spa will be available to you all year round. The seating can be more comfortable and you can have better jets.
Jimrahbe
14,460
Bedford, TX
31,
Have you ever been in a gunite spa before??? If not, I would advice you to try one before you "buy" one.. My guess is that gunite spas are the most oversold and yet most underused items in all of pooldum.. There is no doubt that make a great visual impression, but they are as comfortable as a concrete bench in a city park. Some people love them, but they are the exception rather than the rule.. Get what you want of course, but just make sure you know what it is that you are buying..
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
This is actually the 4th home we've had with a pool. All but one pool had a spa. We love it, and use the spa more than the pool itself. If for no reason other than it's warmer! I've been in a fiberglass spa/hot tub once in my life. Wouldn't be opposed to one but it needs to look the part and not stick out like a sore thumb next to this pool.
kimkats
41,329
Tallahassee, FL
We can pretty up the outside of the standalone so it does not stick out too much. There are lots of ideas out there!
You know what your wallet can take so let us know what way you end up wanting to go and we can help along the way!
Kim:kim:
Gorilla83
418
Thornton, PA
John - Love the house and the project! You definitely have your work cut out for you but everything is fixable and you can make it your own while doing so. Man, you really change houses quickly. :) I'd love to come check it out sometime.
Jimrahbe
14,460
Bedford, TX
31,
My guess would be $5K for two new VS pumps and a new filter installed... I would add automation and a SWCG for another $2K installed.
SeaNile31
Active member
Jul 11, 2018
39
Chadds Ford, PA
Despite it being in the mid 30s yesterday they spent the day trying to clean up the back yard a little bit. You have to look hard to see any progress but it's a step in the right direction. The huge tree that fell and took out the pool equipment plumbing is gone and they removed a lot of branches, brush, etc.
Reactions: Teen124
bmoreswim
Platinum Supporter
5,413
Central MD
Progress.
30’s is great weather to work outside if you can wear gloves. It keeps you from sweating so much! I just came inside.
