It'll be a dedicated theater room. 5 QSC 153KW for LCR and rears. Not sure if i'll put the side speakers on to make it a 7 system,. I forget how many subs I already have, either 4 or 6 CHT 18" subs and I will put in 4 atmos speakers now that there are several options for tile 2x2 speakers (probably will go with JBL).
Really wish it was longer but I'm thinking the front area will take up about 30-36" to hide everything behind the AT screen.
Ok you know what u r doing so we can expand on this.
At least 36 inches cause u need to have treatment on the wall behind the screen. So that will take up some space. But might take up more depending on who specs those treatments. But ya 36 give urself. At least.
Do 7 channel for ur bed audio. Space those sides a bit forward of ur ears if monopoles. I only use monopoles for sides. Atmos specs from Dolby rather monopoles vs bipoles.
Then space your tears as per thier specs.
Much much better for atmos.
Your ceiling speakers as you know have to be properly placed. That depends on manufacture due to dispersion patterns. Triad gives us a calculator for that. What does qsc have for atmos?
Subs up to you as you know. I like to do 2 up front and I balance with 2 in the rear for most rooms we do cause they are usually similar in size but triad helps us with that or whoever we use for acoustics.
You know all rooms are different.
So are you using qsc eq’s Also? That’s a whole other world.
What kinda screen and projector you thinking? Real 4K is finally mainstreaming in thexprojector world. It’s nice.
What stinks is how more and more companies are leaving physical media behind. Oppo not producing new players was the first nail in the coffin now with Samsung saying also others will follow.
Dedicated rooms I feel should be physical media only or a very high quality server that is a real 1 to 1 copy.
