Hello everyone.
My AbGrPool, 20720gl
TA 110, pH 7.5, FC 3.5 TC 5.7, CYA 40, WH 225, phosphate 1000, water temp 83
Over the last week, our weather has been rather wet with almost zero
. Weeks prior to this, weather was cooperative and pool water for the most part tested, looked and felt great.
For the past few days, we've had literal yellow algae sitting all over the bottom of pool floor.
We threw in 2 gl 12.5% liquid chlorine the night before. At first, because I didn't know better, I performed a routine vacuum\backwash.
The next morning, to my dismay, the floor was covered again. I called our pool servicer to see what our next step should be. Found out our vacuum process was wrong (shooda been to waste) and our chlorine shooda been more than 2.
So, we vacuumed to waste, brushed the pool and waited till next morning. Yet AGAIN, algae everywhere. I went to another pool store to get their opinion and\or secure their team to exterminate our algae problem. They suggested taking photos bringing in a sample. Once there, they arrived at the numbers and determined we had high phosphates (everything else in decent shape). I purchased some Yellowout product as recommended by the owner. My process to follow was... vac entire floor to waste, sweep floor, added 3 pounds of Yellowout, waited 5 minutes, added 3 lbs of powder shock, filter for 24 hours.
My issue is that only after 2 hours after adding the shock, the pool floor is starting to accumulate WHITE algae. I thought the Yellowout was supposed to ELIMINATE the algae. Where did my thoughts go astray?
Is algae the only organic that can slip through a sand filter or ANY organic can literally slip through?
My battery is low, so I'll sign off for now and follow-up later.
Thanks
Mike
Thanks
Mike
