The CYA test you are using is the best one available for the residential pool owner. The TF100 has a test that will measure down to 20 ppm. But what you have is sufficient.
Others have noted this before but just a reminder, the CYA tube is a logarithmic scale which is why it is suggested to round up to the next "10th" number, i.e.. 30, 40, 50, etc. Don't try to interpolate between the whole numbers. So it is never exact, even though some pool stores will sometimes put "exact" numbers i.e. 93 or 156. The minimum CYA on the FC/CYA Chart is 20 with recommended range of 30-60 for non-SWCG pools and 70-80 for SWCG pools. So continue to wait a couple to 3 days and test again. You can always buy more R-0013 reagent if needed.Is there a kit or test I can get that can accurately tell how much CYA is in the pool? The K-2006c has a small bottle which you empty into the small tube. But the tube readings do not go below 30, and you have to estimate lower reading, and there is no way to estimate anything below 20 or so.
You are doing fine. Dump the PB's services and don't let him touch your water chemistry again. He will only mess up your good work.Tested again today.
FC: 2.0
CC: 0
pH: 7.6
TA: 225
Added Chlorine to raise FC to about 2.5.
Added MU to lower pH to 7.4.
Will test again tomorrow.
I should be sending a bill to the PB for maintaining the pool for them over the month. They abandoned me due to Thanksgiving week. Emailed me yesterday said earliest they will come out is Dec 3. So much for helping me get this going.
Ask for some "chemicals" since you had to buy them on your ownTested again today.
FC: 2.0
CC: 0
pH: 7.6
TA: 225
Ask for some "chemicals" since you had to buy them on your own![]()
It does not matter if you test before, during, or after the rain.I was referring to holding out with test until after rain passes. I remember someone telling me good to test after rain, so I thought would be good to wait until after rain, then treat if needed.
Semantics. Rain will/does affect a pool's chemistry. It has to. But it would have to rain a LOT for that to matter in terms of general pool maintenance. So you're right in thinking that rain might affect the results of your testing, however little. But Allen is right in that it doesn't really matter (assuming it is not some sort of deluge, or multi-day rain event). If it's just as convenient to test your water 30 minutes after a rain, then do so. But if it's raining and it's going to continue to rain past when you need to test, then test in the rain. You may also sing in the rain, but that won't affect the test results either.I was referring to holding out with test until after rain passes. I remember someone telling me good to test after rain, so I thought would be good to wait until after rain, then treat if needed.
Got news for ya. You already have!I'm such a newb, but hoping to ramp up quick.
Numbers look great!After I dosed in am, I just tested water again.
It is now:
FC: 3.0 ppm
CC: 0 ppm
pH: 7.4
TA: 225 ppm
You're already doing it, which is why you're seeing TA come down. There is a more aggressive method, but it's not needed for now, with this young of a pool. Just keep adjusting pH as you have been and TA will come down on it's own. A while from now, if TA gets stuck too high, then we can try the other way. (Sorry, I only got two thumbs!At some point, maybe you can advise how to lower TA. I assume this will be after FC stabilizes and pH too.
And you won't if you stick with TFP!No I don't smell any of the public pool chlorine in my pool.
