I bought the 8oz size and used it up quick when adjusting my CYASo far i tested my times since pool guy ducks. This is worth it even if I use a quarter if it.
I am sure when stored properly, this shelf life can be greatly extended. But this opinion is for me not for tfps.
Thanks for the guidance.Testing CYA ten times annually (which is plenty), that works out to a 6.5 year supply.
While R-0013 is the most inert chemical we use, I would not advise TFP's to keep any reagent over 2 years.
Hey they are in Texas and we know they always go bigWell... @ciaka got a little carried away. I had originally suggested the 16oz size for $15, which is a significantly better deal than the 2oz size, especially for one that needs or wants to test often during their learning curve...
Perfectly fine. Just double-check the math so you don't accidentally go over. Someone here might as well. I've never used a tab so I don't work with those equations...I bought a box of those trichlor tabs, and am thinking to use them up. Online found about 1 lbs of the trichlor tabs (about 2 of the 3" tabs), will add about ppm of CYA to 10,000 gal pool. So with mine, I would assume, 7 of these tabls will increase my CYA by about same.
So am thinking to put 3 or 4 of them into the chlorinator, so that I can use them up, and get the CYA up too without adding dry stabilizer. Already bought them, why not. What do you wise men on here say? Thanks.
You know that PoolMath app you just raved about? It's about to get better. Go to the menu then select Effects of Adding. Set it to Trichlor, one pound, and you'll see that for your 34,000 gallon pool the one pound of trichlor it will raise the FC by 3.2, raise CYA by 2.0, lower pH by approximately 0.2 (for TA of 80-120), and raise salt by 2.6. Just verify the number of tabs to weight, I don't know that off the top of my head. Or weigh them with a scale.I bought a box of those trichlor tabs, and am thinking to use them up. Online found about 1 lbs of the trichlor tabs (about 2 of the 3" tabs), will add about ppm of CYA to 10,000 gal pool. So with mine, I would assume, 7 of these tabls will increase my CYA by about same.
If you log the addition of trichlor tablets, you can also check out the Summary page and see the total amount of CYA you've added over time from all sources of CYA, with a breakdown of how much was from what source (dry stabilizer/dichlor/trichlor). This last point only if you have the paid subscription so logging is enabled (which I highly recommend).
It is indeed a really great app!
I usually always add an extra splash or two of chlorine. A little too much will do no harm. But not enough can lead to algae, or unsanitized water. Better to goose a little than to be shy with it, you can't really get carried away with chlorine unless we're talking about gallons.
For pH, dead-on is best. Too little acid can lead to calcium buildup on your pool finish. Too much acid can lead to corrosive water, which is not good for any plaster, let alone new plaster. pH is one of the most important to keep at your target level. Fortunately, it's one of the easiest tests to do, and to get right.
