- Nov 12, 2017
- 12,647
- Plaster
- Pentair Intellichlor IC-40
ciaka, Allen is quite right about the tablets. And you're experiencing what I cautioned about, you wanting to dose correctly, as per TFP guidelines, vs the pool guy wanting to do it his way. The tablets will add CYA. It can build up fast. A lot of pool maintenance "pros" don't fully understand CYA and how bad it is for your pool when it builds up to too high a level. It doesn't evaporate or dissipate like chlorine does, it stays in your pool and builds up over time. Eventually the CYA level gets too high and you can't keep the pool properly sanitized. So then you have to drain some of the water and replace it.
That's what you need to guard against while the PB's team is in charge of the chemistry. Test the CYA every so often and monitor its build up. If it gets into the 20s, then it's time to have a conversation about your expectations for your pool's chemistry with the PB. Explain that you don't want the CYA to get above 30, and that his maintenance guy needs to stop using the tabs. Volunteer to take over the chlorine detail. See what he says. He might be glad to have you take over at that point.
With any luck, the PB's one-month regime will be over before the CYA gets too high, and then you can take over and more closely follow Allen's instructions.
Don't sweat it too much, if the CYA gets above 30, it's not the end of the world. You can always fix it later.
