Doughboy above-ground pool with Hayward PowerFloLX pump - installed 7/28/2021
Swimline 87501 auto chlorinator installed October, 2022.
Here is a list of the issues we have been having. In no particular order:
1. Water is gorgeous and clear one day, and murky, green and gross a few day's later. Chemical levels don't appear off enough to produce this problem. We adjust as necessary and even installed an auto chlorinator so that we would not have to worry. Still no real improvements
2. Greenish water in pool does not produce discolored water during backwash/rinse. Seems strange to us.
3. Seeing air bubbles coming out of return jet.
4. Our pool cleaner (Baracuda Zodiac Ranger) loses suction after a couple of minutes. This may have to do with problem #3 since it had worked when we first had the pool installed. Yes, we do blow the air out of the vacuum hose before using it. The vacuum starts off strong but quickly slows down then eventually stops.
If any of you have ideas or solutions, I would appreciate your input. Thanks so much!
