BURRRR to the max! So I saw fire! It looked like it came out of a rod or such???
Flexpipe? Why that instead of hard pipe? Is it going to be deep enough to avoid freezing?
They were using a propane torch to warm up the plastic conduit for the lighting in order to bend it for a couple of the curves. The flex pipe is the standard that the PB uses. The spa will be run year round (shouldn’t need to worry about freezing) and I hope the rest is buried enough! (I’ve been away on travel and haven’t had a chance to talk with the crew).
Today we had the site all back filled and stone put in place for the decking. All levels have been set as well. Still no guarantee on the concrete being poured until the spring. Hope for a warm week coming up and we will see if they can get it done! Regardless, work will continue on the spa as a structure will be built over it which will be heated so work can continue.
Will put the video up tomorrow, but for now here are a couple of pictures.
