Yeah I just noticed that too (which is sorta bad). Sorry for sounding snippish wasn't my intent.Was posting from my phone and signatures are not readily visible.
??? What’s this mean??
Are you logged in using your TFP log in and password?Merged Thread - Marty - TFP Mod
I just subscribed to start using the app rather than my old log. I can log some chemical additions, but when I try to enter a test log (after inputting all the info) and save, it asks if my phone went for a swim. I assume it's failing to connect to the internet for some reason, but other apps still use the internet fine, and I'm not sure why it would need to connect to the internet to make a log entry. I also tried unchecking Log Weather, but same result. Anyone seen this before?
Matt
Hi Marty and Redth,
Yes, I was logged in. Closing the app and reopening does not resolve, but the problem seems to be intermittent.
With combined Cl and temperature tracking disabled in the settings menu, there were two versions of logging screen that came up when I went to log test results. One version included those two parameters, and the other did not. It appeared that when the version of the logging screen came up that showed those parameters, that's when I would see the error. If those two were not visible, the log saved fine.
However, it isn't about those parameters exactly. After enabling them in the settings menu, I can include them in the log and save it. The problem was specifically when they were disabled in settings, but the log screen showed the parameters.
Matt
