Pool Math........The App
JuYuHu
103
Houston, TX
Ok, I've adjusted my values... I was estimating halfway when I wasn't sure, but I subtracted the last drop. Just did both again with
FC 4.0
pH 7.9
TA 110
CH 240
CYA 20
Temp 63
PoolMath Site = 0.27
PoolMath App = 0.18
Not sure why this is... I'm using 20,600 as size and plaster/bleach set up. I have 0 for salt and borate in the website and no entries in the app. The only difference is that the app is tracking weather. What could I be doing wrong??
Leebo
Admin
9,702
Eastern Ohio
If I may ask, can you please hit F5 on your PoolMath webpage to refresh?
As you likely know all forms of chlorine add salt. Salt is a minor player in the calculation of CSI and some number had to be inputted into the formula for things to work. Years ago TFP used zero for the default salt level however we updated that to 1000 for a more realistic level thus giving you a more accurate CSI level. Once you hit F5 on the webpage things will match.
Leebo
Admin
9,702
Eastern Ohio
Also my gut says you’re gonna end up with the App saying 0.18 while the webpage saying 0.19. This is due to rounding differently and will have zero effect on your pool.
JuYuHu
103
Houston, TX
Ok, I togged on track salt. Still showing 0.27 website vs 0.18 app... driving me a bit crazy here. Which should I go with? I swear the test values match in both places, lol.
JuYuHu
103
Houston, TX
I am getting 0.27 CSI on app and web using your new data.
Ok, I had left Salt blank in the app. When I put in 1000 vs 0, NOW I'm getting matching values!! Thank you both for your help!! TFP follower still in training. :)
So for more accurate estimate, should I put 1,000 for salt in the website?
mknauss
29,499
Laughlin, NV
Delete the value in salt. Then go to settings and deselect Tracking Salt. You should still get the 0.27
Leebo
Admin
9,702
Eastern Ohio
Also as a suggestion, hit F5 to refresh your webpage version. It’ll update to match the math besides the rounding, but that’s a very minor issue.
drewhiggs
89
Georgetown, TX
I’ve started to see it’s easier to post a screen shot of test results vs posting them from memory in text form. Would you be able to add an option to “copy” the results in the app and then “paste” them in a post?
drewhiggs
89
Georgetown, TX
Home
Build Type: Plaster
Volume: 15500 gallons
Latest Test Result Summary:
FC: 3.0 (5 days ago)
CC: 0.5 (5 days ago)
pH: 8.0 (5 days ago)
TA: 90 (5 days ago)
CH: 328 (5 days ago)
CYA: 40 (5 days ago)
SALT: 3200 (5 days ago)
TEMPERATURE: 55° (5 days ago)
CSI: 0.05 (5 days ago)
Awesome! I completely neglected that option. Thanks for pointing that out! It works like intended.
RMcGirr83
822
Tuscola, TX
I can't seem to get readings to "stay". If I touch one of the squares, like FC, it takes me to input a reading and get what I need to do but the reading never displays on the main screen after touching the check mark. This is using the Android version if that matters.
