- Sep 28, 2018
- 224
- Plaster
- Pentair Intellichlor IC-40
TLDR: pH rises from 7.2 to 8.0 in 60 hours, but @JoyfulNoise said he is able to go 10-14 days without adding acid due to proper TA and Borates. I'm wondering if I should lower my TA a bit, increase my CYA a bit, and add borates?
Hey all, so appreciate your help both directly and indirectly through just reading through the forums. My pool really has been trouble free in terms of chemicals and I can't understate how satisfying it is to have simply never had algae, never had eye or skin discomfort - TFP has made it a very simple series of concepts that are remarkably predictable.
However, the pH is just going up way too fast for my preference. On Thursday at about 7pm, I tested pH at 8.0 and put in the suggested amount of muriatic acid to bring it to 7.2 (I know that's low, wanted to see how it would affect the rise). I tested at 7.2 two hours later at 9:30pm. Just 12 hours later, the pH rose to 7.4 (Friday at 9:30am). I did not test the water yesterday but this morning at around 9:30 the pH was 8.0 again.
I generally test my water 2 or 3 times per week and my pH is ALWAYS high so I'm ALWAYS adding around 16oz to bring it from 8 or 8.2 to 7.4 nearly twice a week because I know in 3 days it will be right back up. While this isn't an awful terrible thing, I'm hoping there's a way to slow down this process so I can adjust only once or twice a week and end up in that 7.6-7.8 range during that time.
RELEVANT POOL DETAILS:
• Filled 04/23 - plaster pebble finish
• 12,500 gallons
• 1 bubbler on a 3hp intelliflo that I keep on 600 RPM 24/7 split in half with a bypass valve so it just barely breaks the surface of the water
• 1 5ft sheer descent that I never turn on because it's messed up and is being replaced
• 1 5ft spa spillover that only trickles over the side with hardly any bubbles visible at the 1700 and 2100 RPM settings I run it at. I only run it for a few hours sometimes on the weekends
TAYLOR 2006C TODAY:
PH - 8.0
TA - 70
CYA - 50ish (I can see that stupid dot no matter what, but based on pool store testing I think I'm getting the hang of what it should look like)
FC - 12.2 (getting pump speeds and timing dialed in and accidentally bumped this up too high)
CC - 0.0
CH - 340
SALT - 3000
TEMP - 86
• 12,500 gallons
TAYLOR 2006C TODAY:
PH - 8.0
TA - 70
CC - 0.0
CH - 340
SALT - 3000
TEMP - 86
