I should also add that underneath stairs is where I want to have a grill and maybe other limited outdoor kitchen stuff (fridge??). Any recommendations for outdoor kitchen stuff under neath this deck area??View attachment 133445Underneath water proofed deck. Other view of where we want to put trex lattice to enclose area underneath the stairs. Also under stairs is where PB built a small retaining wall on Thursday because they had to dig out to flatten whole area under the deck. The retaining wall is covered at the moment in that black plastic sheet as it is probably close to “cured”. Is that the right terminology??
LOVE THIS! Acts as an accept for the pool! Are you going to color it or stamp it different to make it stand out?Getting a separate border right around the pool.
Make sure the pipe leading from it is big enough to handle that amount of water.The drain actually hooks into a down spout right on the one left hand corner of the deck.
What kind of light posts??? What kind of lights? Will you be able to turn them on and off on their own? Just in case you want only one or two or all of them on to set the mood.We are getting four light posts on the outer edge.
What kind of fence?Fence will be around entire border of pool and fence will be between stone posts.
Love this idea.....be know it can get hot. Get a cheap piece and see what you think after you let it sit in the sun.We are considering artificial turf for this area so no mowing or trimming will need to be done inside fence area. Looking for opinions on this! Looking for opinions or pics on types of artificial turf if anyone has done this before!
SO SMART!!! I would also have towel hooks in that room. I would love to see that room to give you some ideas on easy of use.Finished basement has a full bathroom so we will have easy bathroom access for pool goers
WHAT FUN! Lucky kids!We have 3 daughters (twins age 8, and 6 year old)
SMART move!!! Love your lot but those trees aka leaves had me worried!!This is where the automatic cover will be stored.
Explain more please. I don't understand this one.There will be a ladder in the middle of the stairs in shallow end that will work with the automatic cover.
SUPER SMART move!!! I am guessing you will have a gate right there that is self closing and locks.....We have a play set outside of the fenced in pool area and don’t want kids or others to HAVE to enter pool area to go to basement.
That is the pump that pulls the water in from the skimmer (rectangle box on the side of the pool right at the water line). The pump pulls in the water and sends it to your filter. It goes out from the filter to the returns in the pool. The returns have "eyeballs" that you can adjust to move the water where and how you want to.Helps water flow?
You can take the mineral pack out! No biggie... OR you can take the whole thing out and put in a SWG as seen here: SWG How It Works - Further ReadingRoast away!
That is a DE filter. Need to find where you plan to back wash that as some areas have "rules" about where you can send it to. See if your PB knows about any rules for your area.Pool filter
That is what is all around the underside of our deck and we LOVE it!! SO easy to clean....spray with bleach water and call it good! It is also very easy to work with!plan to enclose under the deck with trex lattice
BUT they turned it from "a piece of concrete" into a work of art!!! NICE!!!! Seeing that makes me wonder just how wonderful the decking will come out if the same people are doing it!!Should add that small retaining wall is just solid piece of concrete.
Photos of small retaining wall construction from Thursday
No idea on the decking steel. I'll ask my pool builder about this. Thank you, never had concrete work done before.SO much to say and comment on!! LOVE IT ALL!!!! Had so many questions and you answered each and every one with your pics and comments!!!
So lets start here-the decking steel. There needs to be something under the steel to lift is up some so the steel will be in the middle of the concrete. If they try to tell you "we lift it up as we pour" NOPE! You and I both know it will sink back down.
What kind of fence?
Kim
Let me help you think this one through..............Do you have gutters all along that side of the house already? If so then not much more water will go into the deck drains so it should be fine. Now IF there is a part of the roof where the water can free flow down onto the decking then you could have a problem as that will add a LOT of extra water to the system.Yes, I think the pipe is big enough, but how would i know before its done?
I am sorry I did not say this when I first saw your house......................I LOVE that stone work!!! It is so pretty! I love your whole house!! You are so lucky!!The light posts will have stone veneer similar to the siding of our house.
I was thinking more of the room the door leads into.I'll post some pictures of the bathroom; honestly, its not much to look at. pretty small, but has a shower.
Oh you will LOVE having that when people who are not as agile want to enjoy the pool! Good move!!Actually, its not a ladder, just a hand rail that is in the middle of the stairs in the shallow end.
OH yes you can!!! You might not know this but all pools end up having salt in them over time. WHAT????? Yeah the chlorine adds salt that builds up over time. It is no big deal!I think we went away from a salt water generator because of the automatic cover; not sure we can have both?
Yes, the separate border around the pool will have a separate stamped look different than the rest of the concrete decking.
Yes, the pool builder is definitely an expert in stone and concrete work; this is a large reason we went with him. He pretty much only does one project at a time. We watched 3 projects of his get done last year before ours was started in the fall. The concrete work on each one was very good.
To comment on the above, yes an automatic pool cover and a fence that cuts off any acces to house is great when you have kids. We put in a pool in 2011 with an auto cover and extra metal fence to block off access from our house and patio to pool. With 6 grandkids, we felt much safer that way. No one could get to pool area without the key to the gate and even then they needed a key to the auto cover. We are in the south hills of pittsburghView attachment 133425View from next to deep end. Showing walkout from finished basement. This whole area is prepped and ready for stamped concrete. Fence will be around perimeter of whole area, BUT in this pic, we are going to have fence cut off area by basement walk out. The idea is we want folks to be able to access the basement walkout and not have to enter the pool area. Fence will go right through the concrete basically following where the canal drain is in this pic. My wife and I thought about this a lot and we think it’s the right decision. Looking for input here! We have a play set outside of the fenced in pool area and don’t want kids or others to HAVE to enter pool area to go to basement. Any comments or input welcome! This is one thing we could actually alter at this point in the project because fence hasn’t gone up yet.
So I found a write up on your Nature 2. It uses two packs. One is the minerals and the other for chlorine tablets. Minerals are a HARD NO aka NEVER. chlorine tablets are okay for a little while but they have extra stuff in them that are good in limited amounts but will build up over time and cause you to have to drain and refill some of the water.
So saying that..............ask your PB if he will take it back. If not then you can keep it and only use the chlorine part until you get your CYA where it needs to be then use liquid chlorine.
We can and will help you get the best set up to keep your pool looking like a jewel!!
Kim
