Is this a good price ..
Status
Not open for further replies.
You want to be sure all plumbing is rigid pvc. You want home runs from each skimmer and from the main drain for perfect control along with jandy never lube valves. You want the SWCG to be minimum 2X pool capacity and what size pipe for each run. And one more, a bypass for the heater utilizing one diverter valve and a check valve.
So my wife does not want to get inground pool. Burst my bubble . She want either semi inground or above ground.
IMO nothing like and inground pool but I'm sure it's a bit more expensive them semi or above ground.
Any opinion on whether semi in ground vs above ground? Thanks
You will likely get a bunch of answers...two that come to mind.
A fence is typically required around a semi-inground pool, as it is considered an "in-ground pool" and most local building codes mandate fencing for any pool that is partially or fully below ground level, regardless of depth; always check your local regulations for specific requirements; you may need to include a fence.
Slope. Either pool should be on undisturbed ground. If you have a slope, you may need to dig some anyway to get to undisturbed ground.
Got it but as far as enjoying , entertaining etc. is semi inground better then above ground.
To me a semi inground is an above ground that is shorter to have to climb into. Once you're in it, you don't see any difference.
Aestheticly speaking, a shorter wrap around deck or retaining wall looks nicer to most.
The semi inground may creep into inground costs, depending on how crazy you go around it, vs just getting a stand alone above ground with a small platform / ladder.
Check this thread and search for similar threads with this model. A bunch should come up. I had one and it was an absolute tank. When I tore it down, the parts in the ground came out as new as the day they were buried.
The price seems reasonable for Long Island, especially for a steel wall pool. I built mine in 2021 and received over 10 quotes from both concrete and steel wall builders. Last year, I helped two friends build their pools using the same builder. In the end, I believe concrete walls are the better option, but my builder was very accommodating and easy to work with—though he only constructs steel wall pools. Back in 2021, the cost difference between steel walls and concrete was about $6,000. All my equipment and pool pic is in my signature. Good luck
Thank you very much. Nice of you.. Who did you use?
Here is another quote I received attached. they email some info which I'm listing below. They are suppose to be very reputable.
Hello,
Please see the answers to your questions below.
1. Are you able to provide model numbers for vacuum set, pump, filter and salt water generator.
- Hayward Vac Kit: SP1067
Pump: SP2610X15XE
Heater: H400FDN
Filter: Swimclear C4030
Salt Gen: AQRS340.
2. I want to do natural gas for the heater.
- Great, we quoted you $4,800 for a natural gas heater on the estimate.
3. Is the filter a cartridge filter.
- Yes, the filter we supply and install is a Hayward oversized cartridge filter.
4. The pump is variable speed?
- Yes, we install a variable speed pump.
5. How many skimmers?
- We would install 2 Skimmers.
6. For the underground plumbing will it be rigid PVC or flexible pipe.
- The plumbing is rigid PVC.
7. How deep will the pool be at the deepest part?
- 6' deep is what the pool is quoted for.
  • Alesi Estimate 031025.pdf
The contracts, WRT equipment are different.
Make sure you get make/model numbers in the contract.
Get the 400K BTU heater. You have to make sure the meter and the piping can handle the BTU. May require an upgrade to existing gas feed.
Get at least a 425 SqFt cartridge filter.
I'd ask for a Hayward Triton 900 or Triton 950 for the pump.
Thank you very much. What do you mean by "The contracts, WRT equipment are different."
Status
