- Jun 24, 2021
- 15,872
- Vinyl
- CircuPool RJ-60 Plus
Ugh ok, thanks.Probably too small for a slide or dive.
All slides and dives have defined "Envelopes" that are required for the installation.
Review the installation instructions for the equipment to see the required envelope.
American National Standard for Residential Inground Swimming Pools ANSI/APSP/ICC-5 2011
To me a semi inground is an above ground that is shorter to have to climb into. Once you're in it, you don't see any difference.Got it but as far as enjoying , entertaining etc. is semi inground better then above ground.
Thank you very much. Nice of you.. Who did you use?The price seems reasonable for Long Island, especially for a steel wall pool. I built mine in 2021 and received over 10 quotes from both concrete and steel wall builders. Last year, I helped two friends build their pools using the same builder. In the end, I believe concrete walls are the better option, but my builder was very accommodating and easy to work with—though he only constructs steel wall pools. Back in 2021, the cost difference between steel walls and concrete was about $6,000. All my equipment and pool pic is in my signature. Good luck
sorry just saw this . I sent you PM.Thank you very much. Nice of you.. Who did you use?
Thank you very much. What do you mean by "The contracts, WRT equipment are different."The contracts, WRT equipment are different.
Make sure you get make/model numbers in the contract.
Get the 400K BTU heater. You have to make sure the meter and the piping can handle the BTU. May require an upgrade to existing gas feed.
Get at least a 425 SqFt cartridge filter.
I'd ask for a Hayward Triton 900 or Triton 950 for the pump.
