- Mar 20, 2017
- 166
- Plaster
- Pentair Intellichlor IC-60
Last fall my sheer descent pump went belly up. Looking to get a replacement. It was a WhisperFlo 1.5hp WF-26. Can anyone recommend a replacement?
poolsupplydepot has this, Upgrade Option that proclaims to be a drop in replacement. Is this a reasonable option given what I had before? It seems as if the wet end of the old WhisperFlo is fine. Is there something esoteric that I need to examine on the wet-end to determine if it really is OK to accept the upgraded power-end?
Or Is there a better option I should be considering? Each sheer has it's own 2-way valve to control output. When running they are at least 2/3 closed so that the sheers don't act like Niagra Falls.
TIA
Todd
TIA
Todd
