IC60 - low salt light, but Taylor kit saying 3400ppm
JamesW
28,291
Maybe the cell is wrong or your test is wrong.
Check the actual salinity a different reliable way.
Get a different K-1766 test kit and a calibrated meter to verify the salinity to be extra sure.
Also, make sure that you are doing the test correctly with good reagents.
Pperc
396
Philadelphia
The reagents are brand new as of a month ago. And the test was matching my old reagents anyways. Im going to plug the lines and take the unit out and replace the thermistor and see
Reactions: JamesW
Pperc
396
Philadelphia
So I installed the new flow switch (just twisting the wires together) and now the flow light is red. So this flow switch is bad OR twisting the wires together isn’t sufficient? Can someone point me to a genuine Pentair flow switch/thermistor?
BowserB
657
"Old" Katy, TX
Pentair Intellichlor IC-40
Maybe/probably not an issue but... K1766 has a +/- error factor. The IC60 has a +/- error factor. Pentair says 3600ppm is both the minimum and ideal salt concentration. Easy and cheap to add another bag of salt.
JamesW
28,291
Also, what is warranty on these?
Ecommerce (EC) products: Products purchased from an Authorized Pentair Online Reseller (products beginning with EC-) receive a one (1) year (parts only) warranty from the date of purchase.
The exceptions are: IntelliChlor cells and IntelliFlo SVRS pumps which receive a two (2) year warranty. EC products are not eligible for the bundled three (3) year extended warranty.
Did I void it?
When did you buy it?
The time to ask is before you begin taking things apart.
In any case, the warranty is probably ok.
09/25/2018
JamesW
28,291
Flow switch has 4 wires on cells manufactured before September 2018:
  • Red/black - flow switch
  • Green/white - temperature sensor
Flow switch has 3 wires on cells manufactured after September 2018:
  • Red - flow switch
  • White - temperature sensor
  • Black - common
The IntelliChlor uses the Harwil Q-12DST-C2 flow switch. It has an integrated 10k thermistor.
JamesW
28,291
JamesW
28,291
Is this a genuine part?
That's the new 3-wire model.
Yours is the older style 4 wire model.
The notes say before or after September 2018, but your cell was made during September 2018, which is not before or after, which causes some confusion.
The flow switch installation instructions seem to indicate that the new flow switch will work, you just need to cap off the green wire.
Reactions: Pperc
Pperc
396
Philadelphia
Yes it does. The switch had 4 wires. So I could buy either the old 4 wire or the new 3 wire based on what I’m reading but maybe the new 3 wire would be the safest bet.
Reactions: JamesW
