- May 17, 2019
- 401
- Plaster
- Pentair Intellichlor IC-60
The flow is fine and solid green. The red and black wires are fine. Only cut white and green.Is the "Flow" light good?
If you don't have a good flow light, then the cell will not do anything until the Flow indicator is good.
Did you damage the flow switch wires?
I have a new thermistor but was trying to avoid replacing it until I closed the pool. Pain in the butt with my pad below pool level.If the Flow light is good, the lights should stop flashing and show a salinity.
Not sure why it's not working.
Do you have a 10k resistor or an extra 10k thermistor that you can connect to the green and white wires?
Do you have a video of the issue?
What automation do you have?
3200 per K-1766 with new reagentsWhat is the actual salinity?
Connect the green and white wires from the new thermistor to the green and white wires going to the cell to see if that makes any difference.
Shut off power, connect the wires and restore power.
Do not remove the old flow switch.
09/25/2018What is the date from the back of the cell?
Try reconnecting the wires like they were.
Is the new thermistor genuine Pentair or aftermarket generic?
The wire colors do not look right.
Are you sure about the actual salinity?
