- May 3, 2014
- 62,819
- Fiberglass
- Pentair Intellichlor IC-40
That is the goal. As I said, there is another check valve on the small line off that three way valve. What does that line do?
Handle should be "down" to completely close the two pipes from the rest of the system.Ok yeah, that is the one I highlighted yellow in the first pic.
Do the handle directions look correct?
Thank you, and yes but it’s hardly ever used.That’s a great pool! Wait, does water really flow of the bbq roof?!?
Got it! I will try that tonight.Loosen the thumbscrew on the handle and rotate past the stops. This is for testing purposes only.
With the spa full and the return side shut off, take some food coloring and place it in front of each jet to see if water is flowing back through them.No, it’s still about a good foot or 2 higher, I’d say.
No check valve in suction line.I think I’ll replace the suction check next
