- Jun 24, 2021
- 16,343
- Vinyl
- CircuPool RJ-60 Plus
Sure, put a cup or two in the skimmer, pump off, scrub, scrub, scrub. Pump on. Dose rest to pool as normal.
An autofill is a skimmer like unit with a float. A water source from your house is connected. When your water level drops, like a toilet bowl, the float drops and turns on the water to refill the pool. How do you add water when needed (when it is low)? Maybe look around for another 6-12" cover around your pool that is not the laminars or skimmers.
Probably, in IL, you don't have one. More common in arid locations where evaporation is an issue.
