My AquaCal SQ125 heat exchanger failed for the second time within three years (while operating in Spa mode). I have a 1.5hp Pentair Whisperflow Pump and my water pressure runs about 12psi in Pool mode and 20psi in Spa mode. I The good news is that both hp failures were covered under warranty.
The service technician was concerned about the nearly 10psi difference between these modes. He suggested I contact my pool installer and have him check for any possible blockage. I removed all six Waterways mini spa jets and ran the pump in Spa mode, pressure dropped to about 17psi with six unrestricted 1” openings.
While I’m considering installing a variable speed pump, my query to the group is whether this pressure difference is reasonable? In reviewing the heat pump specifications, it should be good up to 50psi although not ideal.
Any thoughts?
Farmerkid
Any thoughts?
Farmerkid
