- May 23, 2015
- 25,697
- Plaster
- Pentair Intellichlor IC-60
You should only need 1-2 drops of chromate indicator. As long as you see yellow, it should be good enough. I only use one drop in all my tests.
Yes, all natural gas and propane heaters are subject to the temperature limitations. Your pool is a huge volume of water and therefore a huge thermal mass to heat up. The cold heat exchanger will cause flue gas condensation and gas combustion always produces NOx as a by-product (even low NOX units produce some). So, if vapors condense in the exchanger, they can produce nitric acid which corrodes the copper or cupronickel. Sulfur in the gas line from low quality gas as well as the methanethiol (mercaptane) used to give gas its odor can form sulfuric acid in flue gas condensates. Obviously 68F is quite warm for condensation and likely includes a safety factor in it, but most of the major brands state what temperature they can be operated at safely without voiding the warranty.
