It is in the unwritten, undocumented list. Lol
You aerate to raise pH. That is the sole purpose. If you have water features and you run them, they will cause aeration.
Aeration is a tool to help lower TA. The process works by using Muriatic acid to lower pH and Lower TA at the same time. You can then use aeration to raise pH without raising TA. It is a process and takes some number of days/weeks to lower TA using this process. Without aeration works the same. Just manage pH with Muriatic and your TA will come down over time, assuming your fill TA isn't high.
Test your fill water TA and report it.
