Any special way you want me to clean this ladder besides rinsing it off with a hose?And actually the over the top guide that you wrote is perfect for us new overwhelmed people, so thank you![]()
Dump it out good and flip it around until there isn’t any swooshing left. Clean what you can get to with a diluted 10:1 bleach mix. Dump some inside anywhere you have access to. It hasn’t been that long so it’s probably not that bad, but we’ve seen those ladders CAKED on the insides with algae. Probably not for you, but it won’t hurt to treat whatever you can.Any special way you want me to clean this ladder besides rinsing it off with a hose?
So when I do the overnight loss, do I subtract it from what I slammed it to or what the reading was?Dump it out good and flip it around until there isn’t any swooshing left. Clean what you can get to with a diluted 10:1 bleach mix. Dump some inside anywhere you have access to. It hasn’t been that long so it’s probably not that bad, but we’ve seen those ladders CAKED on the insides with algae. Probably not for you, but it won’t hurt to treat whatever you can.
No I measured to 10 but my slamming target was 12. Thanks!Did you measure 12 or was that just the target you added to? Either way, 3 or 5 is greater than 1, so the test fails. Keep Slamming.
Make sure when you do the ONCL test in the future that you don't add any chlorine after the last test.
So you added bleach to get back to 12. You started at 12………Last night reading at bedtime was 10 and I slammed it to 12
……. And ended at 7This morning the reading is 7
It looks amazing! A couple tiny little gray spots which I’m assuming is algae, when we brush and vacuum they go away but so much better!So you added bleach to get back to 12. You started at 12………
……. And ended at 7
12-7 = 5. As said above either
failed. But we expect to fail for a while so don’t look at it as a negative. It’s just part of the process.
Now, I like you to get the experience so I will be thrilled if you continue, But not having clear water means you don’t have to OCLT at this stage if this ever happens again. Your eyes are a test too and you fail. Once the water is clear, then you start OCLTs. But get the practice in now.
Speaking of clear water, how’s it lookin
I got my speed stir too and that is the neatest little gadget!It looks amazing! A couple tiny little gray spots which I’m assuming is algae, when we brush and vacuum they go away but so much better!![]()
Do you think I should take your filter cartridge out and wash it? Or at least check it? The reading hasn’t gone up, but I didn’t know if it would be good to check it?I got my speed stir too and that is the neatest little gadget!
It’s easy enough to bust it open to see. If you haven’t cleaned it since the water had been clear. It’s probably pretty funky. A quick hose down either way will certainly help.Do you think I should take your filter cartridge out and wash it? Or at least check it? The reading hasn’t gone up, but I didn’t know if it would be good to check it?
So the last time I cleaned the filter the reading of the psi did not go down at all even though the filter looked really clean. Should I use TSP this time? I just used the hose and water last time, and I was reading about the tsp.It’s easy enough to bust it open to see. If you haven’t cleaned it since the water had been clear. It’s probably pretty funky. A quick hose down either way will certainly help.
I’m not sure, I’ll check. The filter is less than 2 years oldDoes your filter pressure gauge go to zero when the pump is turned off?
Could be time for a replacement.
Try a high pressure nozzle to get deep into the pleats. Don't use a pressure washer
as they are too strong for the filter media.
I did clean it like that last time, just didn’t know if I should add a cleaning chemical?I’m not sure, I’ll check. The filter is less than 2 years old
I wonder how I tell if my gauge is bad?Gauges can go bad, so give it a look. I know TSP can help clean suntan lotion/oil
from the cartridges but I have never had to use it. Someone else will chime in
with more info for you!
Thanks! It went down to zero so I think I think it’s fineTurn off the pump. If the filter gauge doesn’t go to zero, you need a new one.
So this morning is free chlorine reading was 6 and that’s the most it’s dropped overnight since I started slamming on Thursday night. I checked the CYA and I filled it to the top of the tube and although the dot is not black anymore if I really really look I can see it. Any advice?Thanks! It went down to zero so I think I think it’s fine![]()
So I repeated the CYA test it’s very subjective but I believe it’s between 20 and 15. I did add 20 at the beginning of slam because my CYA was zero but I’ve been slamming for 30.So this morning is free chlorine reading was 6 and that’s the most it’s dropped overnight since I started slamming on Thursday night. I checked the CYA and I filled it to the top of the tube and although the dot is not black anymore if I really really look I can see it. Any advice?
