- Nov 12, 2017
- 11,961
- Plaster
- Pentair Intellichlor IC-40
I have been following your installation experience as my pool needs MA every 2 - 3 days to keep PH below 8.
Have you read the Amazon reviews on the IntelliPH and seen the problems others have had? Specifically:
Parts need to be serviced annually at a minimum!
ByJLMon September 30, 2015
I installed an Intelliph system along with a pentair pump and chlorinator in June of 2014. As of a couple of weeks ago I noticed acid staining underneath the pump. In fact my two children noticed the staining and thought it was mud. I contact Pentair to file a warranty claim as the pump went bad and leaked. Little did I expect to be told that [actual emails] "The whole unit is absolutely covered by a three year warranty if anything goes bad with it. The only difference with these pumps is they are a wear and tear item and do have to be replaced every year. This also makes it not a warrantable part because since they have to get changed out annually it does not fall into the perimeters of warranty."
So I ask in relation to the annual replacement "I did not see where I was supposed to (in the owners manual)" The reply i get "Yes the tube fittings in those units need to be replaced yearly because there is Acid running through them and they will eventually fail. There is a kit PN 522152 which rebuilds those motors, which is mainly replacing the suction tubes....it is an IntelliPH system it's on page 10 of the OM."
Please PENTAIR please show me where in the OM it states "this is a part that needs to be replaced at the minimum once a year"
No where in the sales brochure, user manual, or in any other documentation purchased with this unit is there ANY mention of a yearly replacement. At the very least this is a safety issue as little kids can be very hurt with the acid, and the worst this is a manufacturing defect. If it is the latter, I wonder why this product is on the market.
What needs to be done is #1 this should be stated in all brochures and #2 those of us who purchased this product thinking it would be safe should be given a rebate or parts as we were sold a defective product with a poor engineering design.
Needless to say this is unacceptable on many levels. I have never in my life seen such a negligent disregard for safety nor a solution for the customer to remedy the problem.
I give it 2 stars because at least it lasted 1 year.
Thanks for that info.
I did read that exact review, before I purchased. It's also made quite clear in the manual. Which is available online, so I had perused that before my purchase, too. So I am prepared for all that. It's possible the manual was changed since the reviewer posted, but no matter, I think that person is being unreasonable. It'd be like complaining about your new car purchase because the dealer didn't inform you that the oil would need to be changed every x miles, or that the tires would eventually wear out, which could cause an accident, which could kill someone, so the car manufacturer should fix your car for free, forever. Like there should be a sign on everything you buy explaining its upkeep? Pentair didn't hide that information from me, I just needed to take a few reasonable steps to learn it. Filter cartridges need to be replaced. Pump o-rings need to be replaced. SWGs need to be replaced. I'm not sure why that reviewer was so in the dark about something that handles a material that can melt plaster might need a little maintenance! I don't believe it's defective. Nor bad engineering. The thing pumps a very strong acid. Some of its parts are subject to wear because of that. That's not a flaw, just a reality. And how about taking a little responsibility for your kids?!? If your kids have access to your pool pad, which includes a four gallon container of acid, 220V, high pressure water, and enough valves and buttons to destroy some or all of your pool, or seriously injure someone in the pool, uh, who's responsible? Yikes.
I was also aware that I might be facing the question I asked. I had read others' notes about diluting. And I had read others' notes that there IpH was not keeping up with demand. So I knew ahead of time this thing might not work for me. And I rolled the dice.
So far I have it delivering enough acid. It's just not clear to me how best to dilute MA, and by how much, or if I even need to. I was just reading a similar discussion about robots, that their manuals say take them out of the water, but at the same time they offer a timer which implies it can live in the water.
The IpH manual explains to dilute the acid, and the unit has a very handy feature that can empty an MA jug without pouring. You just slide it into the dispenser and it pierces the jug for you. But then how is one supposed to dilute the acid? The same manual states you don't pour water into acid!! Like the robot manual, I'm guessing Pentair includes the dilution language to support warranty denials. Like if the motor gives out too soon, they can ask "Well, did you dilute the acid first? No? Well, no soup for you!!"
Others claim they are using MA full strength in these things. Others are diluting. I'm just seeking thoughts on the subject, and maybe an MO that someone has worked out for this dilemma.
