- Nov 12, 2017
- 12,636
- Plaster
- Pentair Intellichlor IC-40
I'm still running 31% 1:1. It's been two months exactly. But I can't now remember if I first dumped in four gallons or three. I think three, because the hopper doesn't really hold four gallons, as I recall. And I added a gallon before I left, and it's still mostly in there. So I'm going to say 1.5 gallons a month.
Since I installed I've been dialing down the output a bit, so now I'm below 50%. Which should theoretically mean I can now switch to 14% or dilute the 31% 2:1. I was waiting to finish off the original three gallons to do so, but then my little vacation happened, and I didn't want to be fooling with changing anything a few days before I left, so I had to add that fourth gallon. So once I finish off what's in there now, I'll switch to 2:1.
I can't just pour in water to dilute now, because the dern hopper is shaped such that there's no way to know what's in there now (it tapers from top to bottom), plus I'm pretty sure the gallon marks on the side of the thing are way off. So I have to wait until it's nearly empty, and then pour in a gallon of water, mark that on the side, then a gallon of acid and mark that on the side, etc. That'll solve both the dilution issue and the inaccurate measurement marks at the same time. I guess it'll be about another month before I can do that...
Glad to hear you've got your system working. Yay! Wow, so you're using over a gallon a week, in a 7K gallon pool?! That must be the new plaster...
