- Jul 21, 2013
- 65,248
- Plaster
- Pentair Intellichlor IC-60
That is less than fully closed. But you are right it really started max flow perhaps 15 or 20 degrees before that. I can play with is when the auto valve is installed. Good new is pump was at 2250 in heater mode, in bypass mode with valve not fully move there, I could lower the pump from 2250 to about 1650, it went from about 700 watts to about 350 watts in bypass!! WOW!!
Now you understand.
