- Jul 21, 2013
- 65,173
- Plaster
- Pentair Intellichlor IC-60
I don't think it buys you anything to change things.Not sure I can easily label a picture. I tried to identify above.
Check Valve 1 on the bottom left is flow meter.
Check Valve 2 is on inlet to 3-way valve.
Check Valve 3 is the black blob on the solar return.
Check valve 1 is on the inlet to the filter. Check valve 2 is on the outlet of the filter, and up to solar control valve.
You can open up Valve 2 and remove the flapper if you want.
