- Jul 23, 2007
- 438
- Plaster
- Pentair Intellichlor IC-40
4,
It looks like a connection fitting for a Pressure Side cleaner.. Do you have a booster pump at your equipment pad?
Edit... I am an idiot.. What was I thinking???
Yeah Im talking about the surface stains and if this is something I can fix...I have been out of town and took my water in for testing....showed a ph at 9.0 which is crazy as a week earlier it was a 7.8.....i added some acid and got it back down to a 7.2 in my last test...but concerned with that "circle" and dark spots on my plaster...is this what some call grey mottle?
I at least got a good laugh out of your response. I thought you were just being sarcastic...then I saw your edit.![]()
The stains are related to the water coming out of the fitting. The black dot pointing to the right is a pressure relief. You can feel the water coming out when the Polaris is on. The water jet lines up with the spot on the wall to the right of the fitting.
