So long as it works. Adapt as necessary. Some dose everyday without testing every other day, others double dose and test the second day. As long as you're always verifying you're not cutting too close to min at the next test, you're golden. Dose as high as you need to, to accomplish the mission. If that's 4 above target range, so be it. You're safe to swim all the way up to slam. Never hesitate to use some of that safety net.With respect to chlorine, I guess I can simply pour 1.5 qt of liquid chlorine daily in the pool and I will maintain the FC within the range I am targeting.
Real soon daily demand will start increasing and you have to account for the new loss. It levels off at the high point for the peak season, then slowly falls week over week for the fall.
For Ph, all highs out of range look like 8. (And same with really low Ph's). So it may be 8.3, but you think it's 8, and don't see it lower when it lowers to 8.1. Mix well for 15 mins, retest, and repeat until it's in range again.
I like 8+ to 7.8 myself. It leaves you some wiggle room to accidentally overdose to 7.6. But there's no wrong way here.and is it ok for me to keep adding MA every day to keep the pH between 7.6 and 7.8?
With new plaster and it's healthy appetite for MA for the first year or so, you may need to raise the TA at times. 50+ is totally fine and the slightly lower TA will help the Ph rise. It still might not be great, but it will be better than new plaster PH rise *and* TA of 80+Wouldn't that, at some point, bring the TA below the acceptable range?
