For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6.1 ppm and decreases Total Alkalinity (TA) by 7.1 ppm.
50 lbs of trichlor in a 25,000 gallon pool will:
Raise fc by 219 ppm
Raise CYA by 133 ppm
Raise salt by 179 ppm
Lower TA by 154 ppm
The effect on the pH depends on the TA and the amount of time that it takes the trichlor to dissolve.
When added slowly and the TA is high, the pH will drop but it will also rise from the TA. So, the net effect will be less than expected.
Raise fc by 219 ppm
Lower TA by 154 ppm
