I posted yesterday Pentair Motor replacement & control Q but did a bunch of research, I need to replace the 1HP full rated 1.65 S.F. motor for my Pentair WFE-4 WhisperFlo pump.
I've ordered the Century VGreen 1.65HP variable speed motor model EPM16SQ which is the almond version of the ECM16SQU. My math shows the motor replacement should have a payback (versus the single speed) in a year or so, but going to a full IntelliFlo pump replacement would not pay back within a say 5 year lifespan.
I'm curious about programming the VGreen with my Pentair EasyTouch4 controller.
Right now with single speed pump, controller is just turning on/off the 240v relay so it's power on/off to the motor. What I'd LIKE is to have the ability to run different programs in Spa or Spillway mode vs. Auto Pool filter mode - I'd like full rpm in Spa and Spillway mode without down-stepping rpm over time, but for pool filter mode, after the prime is done then run it in reduced rpm mode, perhaps with a step-down over time.
I see two ways to program it according to the VGreen User Manual. (also attached), which for some reason has a totally different and less-straightforward control panel, UI and programming model than the VGreen 85 or 270, at least according to these docs that I got from the Regal/Century Website (manual links on right hand panel)
1) (the easy way that I know how to do) is to run motor at full speed for 60 (or 120 minutes, only seems to take full hour durations) and then step down, perhaps to a slightly lower rpm after 60 minutes, then 60 minutes later do it to say half rpm, which should use about 1/4 the current / kwh.
2) (that I don't know how to do with the EasyTouch) is use the digital inputs on the motor, looks like holding +12v low on pins 1-4 (or using 24vAC +-20%) on pins 1-4, allows it to go directly into programs 1 through 4, so I could have different programs for Pool vs. Spa and Spillway (I can use Spa for Spillway). What I don't know how to do is both wire and program the EasyTouch controller with relays to do what I want. However, the manual is confusing. Figure 4 on Page 11 shows 5 pins on the 'digital connecter' (pins 1-4 plus ground) that I can use 13-30vac or 9-30vdc to set the pump into program modes 1 through 3 (or override). The picture in Figure 5 shows a header to the right that I assume is the 5-pin, and the actual RS485 digital connector in the middle, so I assume that Figure 4 refers to the 5-pin pushing header on the right, that I'd push in say 18awg wire? And all that's necessary is to have a replay hold power (ac or ac) to one of the 4 pins, and the appropriate pin always goes into the program (ie. program 1 for pin 1, program 2 for pin 2)? I get that, but not sure how to program or wire the EasyTouch 4 to do that with a couple of output relays, if there are spares (mine is the stock EasyTouch 4 with dual spa/pool control from a single motor w intake and output candy valves)
Also 3) Some mystery (to me) way using the RS485 true digital controller, no idea how to do this, even if I added the (as I plan to) protocol converter (not wireless, plan to hardwire it since it's close to ethernet) so that I can program the EasyTouch from my PC and use the smartphone app.
Has anyone successfully done this (#2 or #3), or something similar, to allow the EasyTouch to operate the variable speed aspects of the VGreen motor?
