I have a 15,000-gallon inground pool with the following:
After doing some research, I am thinking the easiest, most cost-effective way of doing this would be to buy and install a Century V-Green 165 motor to replace the burnt-out motor on my super pump, this way I don't need to mess with any of the plumbing. And for automation, install the Pentair IntelliConnect Pool Control & Monitoring System. I can not find anything that specifically tells me if the Intelliconnect and the V-Green will work together. The website for the V-Green says it will work with third-party automation but that's about it and I'm not finding anything on the internet about this combination.
Basically, I would like to have mobile access and ideally voice control via Google Assistant, to the pool pump, possibly the light switch. That's it, no valves, waterfalls, real basic.
- 1 pool light that works off a switch inside the house, which is not working at the moment, I suspect needs a new bulb.
- Intermatic basic mechanical timer, which needs to be replaced, not keeping time
- and until it stopped working yesterday, a Hayward Super Pump, single-speed, 1 HP which I installed in 2017
