- Apr 5, 2022
- 95
- Vinyl
- Hayward Aqua Rite (T-15)
So I'm hoping to get some opinions on what I should do. I have a 22,000 gallon in ground pool with all hayward equipment, a vsp pump, hayward heatpro electric heater and currently a Pentair 3" tablet chlorinator. Since I have a hayward omni with the full automation where I can control everything through the hayward app, should I consider the Hayward aquarite T-15 (most expensive at around $1800 on amazon). If not Hayward, it sure seems like a no brainer to me to go with CircuPool. I have it potentially narrowed down to these choices but open to more suggestions:
1. Hayward aquarite T-15 (if its worth being able to control it all through the app). If I chose this one, could I easily DIY or would it be harder?
2. Edge 40 - $1200
3. RJ45+ - $1500
4. RJ60+ - $1700
My understanding is the circupools are more designed for DIY and though I wouldn't get any automation through an app, I could still set it to a certain level and probably work out a timer to have it kick on. Would I be able to plug the salt generator into a standard outdoor wall plug? I have several of them right near my setup. I assume it also could maybe be wired into my existing omni stuff, but not sure how confusing that would get. Other than that, it appears I could just cut the plumbing out where my existing 3" tab chlorinator sits just passed the heater (probably have a 3 ft straight plumbing line or so through there) and set the salt generator up there? I'm pretty IT minded and decently handy at fixing stuff. Is this something I could do myself, or should I hire somebody?
As far as the rest of it, for the most part it sounds like all I'd have to do is hook up swg, figure up how much salt I need and dump it in the pool, get settings right, and for the most part thats about it? Anything I'm missing?
Would be open to any suggestions on what SWG to buy especially. Since my pool is 22k gallons, is the edge 40 enough? That seems like the best value. I already can monitor my temperature in real time through the omni app so not sure what else the RJ45 would bring to warrant $300 extra dollars. Also not sure if I should stay with hayward and get that but it seems like tech support would be really low with that.
2. Edge 40 - $1200
3. RJ45+ - $1500
4. RJ60+ - $1700
