Thought I would give an update on the pool light. As ajw22 suggested, it was not the transformer. It was definitely the pool light itself. The pool light was covered under warranty and it finally got replaced a few weeks ago from the pool company. The only annoyance is the Omni Hub settings. So I have an Omni Hub and control the lights through that. With my old light, I had Omni Direct setup that was very straightforward to do in the settings and it allows the lights to change from say Red to Blue instantly without having to cycle through all the lights. Well with this new light, now Omni Direct does not work. Omni Hub will allow me to set it to Omni Direct and it thinks it will work, but in reality it doesn't. If I go to change it from Red to blue say, no matter what option I select it keeps navigating through all the light options in a pattern, with every button I press. So if I try to change it from red to blue, it may go red to green instead. If I try to set the brightness to 50%, it will change it from Green to Blue.....all options I press either on the panel itself or in the app just makes it cycle through the next light in the pattern.
I did a lot of research on this site and google, deleted the light off Omni Hub, readded it, etc. and nothing works. It will work when its not in Omni Direct mode as its supposed to so I decided to just give up on it for this year and either live with it having to cycle through lights the old way or worry about it next year. I read that you may have to reset your whole Omni Hub system to get it to work, which I really don't want to do since I have a heater, pump, swg and all. I did read a thing saying all lights manufactured before X date (I think it was 2019) is not compatible with Omni Direct. I started to get ticked off thinking did the pool company give me an older light? It's possible but I really don't think so. I saw them open the sealed box, get it out and it is definitely the exact same model #. I guess I could pull the light out and check serial number but I really don't think the light is 4+ years old. It's probably a settings issue but who knows.
As for Hayward in general.....man I just really don't know that I could recommend it to folks. For those counting, all evidenced in this thread, since January 2021 when pool was finished I have had to replace almost every Hayward part (all under warranty at least). My Hayward parts are the VSP pump (replaced under warranty), heat pump (i diagnosed and manually replaced a capactior for ~$15 at beginning of this season), light (replaced under warranty), Aquarite T-15 SWG (bought it last summer, installed myself, and working great for now), and Aquavac 650 Robot (also replaced under warranty with a tigershark qc because they've discontinued it). I think if I were going to do it again, I would buy parts from a brand that's more user friendly to fix when stuff breaks (if that even exists). The pool light for example is a known issue with a million complaints saying that in another 2-3 years that will go out. I have a narrow niche that they installed so almost no 3rd party lights work, so I don't know what I'm gonna do in 2-3 years when the light goes out again. It's like $1200 for that light. Hopefully by then they have a cheap chinese made turn key one that I could use instead because I'm not spending $1200 on it. The only positive I can say is I did get almost everything replaced right at the end of the warranty but I'm basically on my own from here on out as far as cost is concerned.
Just thought I'd update the post and vent a little lol. The help here has been beyond amazing on not only teaching me about pools chemical wise, but also helping me with troubleshooting. One advantage of all this stuff breaking is I am quickly becoming an expert on how to diagnose and fix things lol. If anyone has any additional info on getting Omni Direct to work let me know. Just weird that Omni Direct was set and working perfectly....and now it won't with the new light.
