- Nov 23, 2007
- 33
I have a 15 year old Starite 400na heater that won't light. This is hooked up to my Aqualogic PS8. A year ago, the pool heater started coming on at random times, so I disconnected the heater until I could fix it. I figured out the keypad membrane was leaking and the control board was damaged. Recently, I replaced the control board and keypad.
Now, when I turn the heater on, I hear the blower come on for a few seconds, I hear a click and smell some gas, and then a click as I would expect the heater to light, and I don't get a flame. After a few more seconds, the blower stops and the AFS light comes on. I think the AFS light is a red herring because the blower basically stops and that stops the air flow. Until the blower turns off, no service lights are on.
I just changed the igniter, and still the same thing. I checked the ohms on the igniter and it was something like 72.4, so I assume that's good. Last year, I took a lower bolt out of the heater manifold and had no water come out, so I assume there is no water in the heater.
What's left? How do I check the gas, or who do I call to check the pressure? What else should I check?
Thanks in advance!!
Robert
Thanks in advance!!
Robert
