Hi guys, I've spent a good amount of time troubleshooting this myself and am out of ideas.
Heater has been working fine for months with no problems. I realized it was not heating one day and it has not ignited at all since then. It goes through the ignition process, everything appears to be working, but there is no ignition when the system clicks - it tries several times and then the service heater light comes on. There are no error LED's at any point other than when they all flash on when the unit is started. The red LED inside the unit flashes 3 times for Ignition Lockout after the unit tries to start. The blower appears to have strong suction in the intake and blowing from the exhaust, I checked inside the exhaust with a pipe camera and the drum looks completely clean/dry, blower looks clean with the camera too, no staining anywhere etc, there is no corrosion inside the unit or near grounds etc that I see. At most the unit is 10 years old, inside is very clean.
I've gone through the troubleshooting process in the manual, which ends up at 2 options: "replace HSI igniter" and "Replace Ignition Control Module" - I tested the old igniter resistance and it seemed to be fine but I had a new one and swapped it, new igniter is also working fine - both were too hot to touch when removing. I tested the leads to the igniter while the system was trying to start, and the voltage I got matched what is supposed to be output, per the manual - a pulsing range under 240v. Lots of gas flowing (unit is right next to the meter) and I smell gas each time the unit tries to start. Spa jets appear to have the same water flow as always and other pool equipment seems to be fine.
So I could try to get someone to diagnose, but that can be a Crud shoot too. Any suggestions? Thanks for reading
edit - the next step I was thinking of is to replace the Ignition Control Module, as that is what is suggested in the manual - but it's not cheap and it appears to be functioning, at least in the ways that can be tested per the manual
edit: Solution was replacing the gas pressure regulator between the gas meter and the unit, which had gone bad - everything else was working normally.
