- May 3, 2014
- 58,660
- Fiberglass
- Pentair Intellichlor IC-40
A salt water chlorine generator is still chlorine ----Sure thing. We are not using chlorine btw.
The proposals I have received has line items, "Automatic Salt Chlorinator". Would that be the same thing?
You need to ask for the specif model they are proposing and determine if the Automatic Salt Chlorinator AKA SWG AKA SWCG generating capacity is at least 2X your pool volume.
Brochure shows rated for 50 gm/hr chlorine gas generation. Stated to chlorinate up to 40000 gallons.EMAUX SSCone Salt Chlorinator is in one of the proposals
On top
Just to clarify, is the pool going on top of this house, or is it going to be on a completely different structure?
The pool will be roughly 17K gallons. 150 L is roughly 40K.
As is it looks woefully under supported.On top
The answers to your questions are all no.As is it looks woefully under supported.
Can you provide some backstory as to why ?
Are there hidden supports we can’t see ?
Did the project change drastically and needs to be fortified to accommodate the changes ?
Did supply issues (possibly covid related) stop the project mid build ?
Did you buy someone else’s half started project?
There are a lot of pieces to this puzzle missing and you can tell us a lot without getting into your own personal details. It would help greatly going forward.
Welp, You didn’t come here for construction advice like you said. You needed chemistry advice which we certainly can do as well. And as friend-ily as I promised.The answers to your questions are all no
The point to this story is that the 40k SWG unit would work just fine in the states, but may not produce enough chlorine in a hot/Tropical climate. If it’s available I would highly recommend a 60k unit because the sunshine is going to LOVE to burn up your FC in the peak season. If a 60k unit isn’t available, I would have two 40k units installed side by side.
That’s a breath of fresh air compared to what we usually see with over hyped manufacturer specs. Unless it’s exactly what we usually see.An IC60 is speced at 60,000 gallons. This SWG looks to be over engineered and with conservative marketing claims, unlike what we see here in the USA.
I think it will do fine in a tropical 20K pool if it lives up to the spec sheet
I get that... I just don't understand what the question is that OP needs help with.OP found us looking for how to manage the pool post build. We shamelessly asked for pics because we love pics. The rest kinda snowballed beyond OP’s level of comfort with sharing.
So we will do our thing and help where we can be of help.
