So not to long ago, I thoroughly backwashed my Hayward Pro Grid DE filter 48 square feet. Also before that I clean out each individual grid, there were no rips or tears however I did find some broken plastic inside a few of them, but not incredibly broken. After putting everything together and adding the correct amount of DE, the filter psi was at around 14-15, which looked normal to me. NOTE our pool is fairly cloudy after an algae battle, so I knew that I was going to need alot of backwashing. But I did shut the pump off for a little while, and I turned it back on and OUT OF NO WHERE the psi in the filter dropped to like 4. It was almost like the fresh DE in the filter just magically disappeared with the pump off for a short time. We have no air bubbles in the pump basket, everything good but I do hear crackling in the multi port valve. The skimmers are working good, but I just cant find out why the pressure just dropped in the filter.
