Seems good in theory, but the "Massage" feature doesn't really work and no one really uses it.Yes sir, return jets are more for masage.
I am a bit lost but I will update the diagram tomorrow based on your advise. Thanks!If you are wanting to use the returns as massage jets, you may be better served to split the 6 returns into 2 sets of 3 and have separate valves to adjust each set. This should help provide better functionality. And have separate massage jets and separate returns - each with their own valves - to allow the best skimming action while also allowing the massage jets to be used when desired. With the massage jets churning the water, your skimming action will be diminished.
The skimmer should be placed on the downwind side of the pool, given prevailing wind direction. Also, have the skimmer pipe homerun to the pad - separate from the main drains ( like shown in your diagram).
That looks much better to me. Gives you many more options on where/how you want the water returned to the pool.This is my new design... please ignore the curves.. but overall design...
Yes it does look better!
I don't have leaves but did check windy and the wind usually blows that way.That looks much better to me. Gives you many more options on where/how you want the water returned to the pool.
Skimmer placement should be on the downwind side/corner of the pool - the place where you would expect leaves on the surface to gather when the prevailing wind blows. It's up to you to determine that location.
Feel free to start a build thread in Under Construction to document your progress and allow us to follow along in your journey. Don't forget pictures, we love pictures.
My design makes sense to you or do I need to add massage jets as well? I got confused on your part of also using massage jets.If you are wanting to use the returns as massage jets, you may be better served to split the 6 returns into 2 sets of 3 and have separate valves to adjust each set. This should help provide better functionality. And have separate massage jets and separate returns - each with their own valves - to allow the best skimming action while also allowing the massage jets to be used when desired. With the massage jets churning the water, your skimming action will be diminished.
