Hello,
I just purchased a Warrior SE from Margaret at Marina Pool Spa & Patio (thanks for the strong recommendations everyone) and now I need to install a new exterior outlet on the side of my house to power it. I have a small overhang off the side of the house (like underneath a bay window) that I plan to keep the power supply under so it's protected from the weather. I'd like to attach the outlet to my Aqua Plus controller box since there's already power there, but it's 6-8 feet away from the overhang where I would want to mount the Warrior power supply. How long is the power cord from power supply to plug?
Also, does anyone control their robot via the Aux relay on the Aqua Plus (PL-PLUS-20G)? I have an external Aqua Plus remote mounted inside the house that would allow me to turn on and off the Aux input but I'm not sure if when you do that the robot would automatically start up when power is first applied to the power supply? Doing this would be pointless if when power is applied you still have to go outside and press the power button on the power supply in which case I'd just mount the outlet directly under the overhang instead (always on/not controlled by Aqua Plus).
Hope that makes sense. Thanks!
