- Oct 25, 2015
- 5,815
- Plaster
- CircuPool RJ-60 Plus
May I ask you, why are you controlling the robot via wifi plug/alexa instead of your Intellicenter? IS that just so you can use voice activation? Could you not wire the power to the intellicenter relay instead of using a smart wifi plug? I'm building my pool now and considering both methods (smart plug vs intellicenter)... so v interested in your experience... thx!
If this was new construction for the house I would definitely have use the intellicenter. But use of the intellicenter right now would require running a new wire through the wall from the pool pad to the back of the house. This would have to be done through conduit at this point or up through the Attic at the very edge and then a new power drop which is very hard to do with cinder block exterior walls. So using a smart controller with just much more convenient and way less expensive.May I ask you, why are you controlling the robot via wifi plug/alexa instead of your Intellicenter? IS that just so you can use voice activation? Could you not wire the power to the intellicenter relay instead of using a smart wifi plug? I'm building my pool now and considering both methods (smart plug vs intellicenter)... so v interested in your experience... thx!
Chris
