Thanks to all for suggestions! Here are plumbing options, adding either 1 or 2 new returns, and another LED housing. Two returns are already installed on the entry end of the pool, as is one LED fitting on the skimmer end.
Input is most appreciated!
Would two LEDs (switched via separate circuits) be too much light for such a small pool? (e.g. subtle mood lighting using the side LED and a brighter LED on the drain end for swimming)
________________________________________________________________
Option1:
- Add a return on each side pointing in the direction of the skimmer using something like this:
- Add an LED on the side of the pool, pointing away from the patio seating.
Option2:
- Add a 3rd return on entry end of pool between the existing returns, providing more flow in direction of the skimmer. This would mean putting it in the riser of the top step to keep it at same level as the other two.
Would some sort of spa jets in this seating area be a bad idea?
b
