DIY Update
It has been a long time since I've posted. After getting the pool set, the retaining wall built around it, plumbing and electric roughed-in, and backfilled with compacted pea gravel, I had to get back to building our house. I finally was able to start putting in some work on the pool again, in August.
With the warm weather the pool had become impossible to keep clean - it was more like green slime than water. So priority was on a temporary pump and filter hookup until I have time for proper equipment setup. I found some used Pentair equipment on Craigslist for under $400.
- Quad DE 60 filter
- Multiport valve
- 2-speed WhisperFlo pump (1.5hp WFDS-26)
- Suntouch system with remote
I needed an equipment pad but wanted that to be a permanent structure. Picture below shows where I brought up the returns, drains and electrical conduit about 30ft away from the pool.
The equipment will be in full view from the pool deck so we decided it needed to go inside a small pool house. With no time right now to build one, I proposed dropping a pre-built shed over it but couldn't get that idea past the "designer"
. I ruled out pouring a slab, wanting future access to the underground plumbing, So I decided on a post-type structure that I see used out here for barns and sheds. That way I could set the posts and fill-in a gravel/paver floor inside them to set the equipment on now. Later, I'll add a roof and wall-in the pool house. Anything under 12'x12'x12' does not require a permit here, so that's the size it would be.
My sketch for this idea was approved
My crew and I started right away setting the posts
A dozen bags of concrete, a few gable boards, some chainsaw work, and it took shape...
I boxed in the the left side with 2x12 P.T. splash boards using galvanized joist hangers. I filled it with compacted gravel and topped it off with some concrete pavers.
The WhisperFlo pump I bought is 240v, but I only have 120v from my temporary power pole. My neighbor came to the rescue and loaned me a 240/120v Hayward pump he had in his barn. After some PVC puzzle work I had the 1.85hp pump hooked to the skimmer line, and the Quad DE filter dumping into two of the 1.5" returns.. I primed the filter per instructions with the proper amount of diatomaceous earth. The filter gauge read 10psi when I started it up, then shot up to 30 psi within a few minutes of pumping green slime. 2 gallons of chlorine, 3 back flushes and 4 filter recharges later, it looked ready to jump in! The 1.85hp pump is way too big. It makes the pool churn like a hot tub.
At this point I was ready to pick up on the pool work where I left off... PAVERS!!
