- May 3, 2014
- 58,609
- Fiberglass
- Pentair Intellichlor IC-40
Liquid chlorine. Add what Poolmath says for you to reach SLAM FC level.
Can you talk to me about testing the CYA? So it says to add water until you can no longer see the black dot...will the tube only goes up to 30 and at that point I can still see the black dot...how do I get an accurate cya reading? I’ve just been putting 30 since that’s as far as tube goes.Welcome! A pool with algae requires the SLAM Process. To perform a SLAM you need either a TF-100 (link below) or Taylor K-2006C test kit. That's very important. If you don't have one, that needs to be step #1. Also see: Test Kits Compared
Don't add anything else to the water except liquid pool chlorine or regular bleach. About one gallon per day until you get the right test kit. Then post a full set of numbers and we'll be happy to coach you from there.
Also review our ABCs of Pool Water Chemistry and read/save those Vital Links below in my signature. Update your sig as well.
So I did download the app- I put in everything and not sure what I’m supposed to be entering as my target?Liquid chlorine. Add what Poolmath says for you to reach SLAM FC level.
That means your CYA is much too low. A CYA below 30 is no good for an outdoor pool and needs to be increased. Use the PoolMath APP to determine the dosage so that you can add about 20 ppm of CYA. Since you are going to start a SLAM Process, you want your CYA at 30 or perhaps 40 at most. That's why I suggest adding only enough stabilizer to increase by 20 ppm in case you have some CYA in there already.the tube only goes up to 30 and at that point I can still see the black dot...how do I get an accurate cya reading?
Adding CYA:
To increase CYA via granular stabilizer, place the required amount as calculated by the Poolmath calculator into a white sock and place in the poolside skimmer basket. For those concerned about suction flow to the pump, suspending the sock near a return jet or from a floating device will also suffice. Best never to allow undissolved granules to rest directly against the pool surface. Squeeze the sock periodically to help it dissipate. Once dissolved, consider your CYA adjusted to that programmed (target) level. CYA test readings should show a rise in 24-48 hours, however some pools may experience a longer delay to fully register. Best to confirm final CYA in about 5-7 days before adding any more stabilizer/conditioner.
Thank you for the info! So what would you recommend me entering in the app as my cya?That means your CYA is much too low. A CYA below 30 is no good for an outdoor pool and needs to be increased. Use the PoolMath APP to determine the dosage so that you can add about 20 ppm of CYA. Since you are going to start a SLAM Process, you want your CYA at 30 or perhaps 40 at most. That's why I suggest adding only enough stabilizer to increase by 20 ppm in case you have some CYA in there already.
Ok I added maybe a little too much stabilizer by like 3 cups ?? . How long should I wait to test again?If I simply wanted to increase my CYA by 20 ppm, I could enter 10 (NOW) to 30 (TARGET), or 0 to 20, or 50 to 70. Any of those will result in the same dosage amount back. When I do it, I get 3 lbs 5 ounces for a 20K pool.
You add drops until the color stops changing. So for example with TA test, after sample changes to "cherry red", when you add one more drop and it gets to "ripe watermelon red" it did not stop changing color. Add another drop, if it stays "ripe watermelon red" the test is complete and use that number. Hope that helps.. . . The only thing I struggled with was the colors..like when it said keep adding drops until it turns from blue to red... so like are we talking cherry apple red or ripe watermelon red. LOL I ended up doing each test twice to make sure I was doing it right. I posted my results on a different thread so hopefully I wasnt overthinking it and completely failed haha.
That’s great. Thanks. I get watermelon ice pop, watermelon ice cream/ bubblegum then actual watermelon.if it stays "ripe watermelon red
Thank you! I’m about to do another test!You add drops until the color stops changing. So for example with TA test, after sample changes to "cherry red", when you add one more drop and it gets to "ripe watermelon red" it did not stop changing color. Add another drop, if it stays "ripe watermelon red" the test is complete and use that number. Hope that helps.
The only test this does not work for is for CYA.
Here are my results from today..what acid do I need to get? Also, The vacuum is at the bottom of deep end...haven’t been able to see that yet ?Thank you! I’m about to do another test!
And here’s my sign I’m asking too much...?oh well! LolAlso I would highly suggest reading the pool school articles. It will answer lots of your questions as well you will learn a ton
