New pool build - Owner-builder
chemillion
Active member
May 7, 2019
33
Southern CA
I think Aqua White is a little on the lighter side. If you like darker, maybe consider Aqua Blue, Tahoe Blue, or Tropics Blue. Not sure on the darker colors being warmer. It would make sense though.
That was our thought too that the the Aqua white is too on the lighter side, unless you add a touch of jewels with blue or black in them. The NPT reps were even suggesting having the plaster Co hand sprinkle instead of mixing in the plaster.
debuda
46
Los Angeles
I have noticed that water that accumulated in the pool just sits there until it evaporates but in the spa it disappears really fast.
I know the shotcrete isn't waterproof but is there something I should do before plaster to make sure the shotcrete is more resistant to leaking?
chemillion
Active member
May 7, 2019
33
Southern CA
Most likely they used rebound on your spa floor which may have created some voids that penetrate to the dirt level, hence not holding water. Once the plaster goes in, it should seal off those voids if I'm not mistaken...
chemillion
Active member
May 7, 2019
33
Southern CA
Where are you at in your pool building process?
debuda
46
Los Angeles
Thanks for the info.
Just passed gate inspection. Trying to schedule plaster.
In my case I paid by the yard for the shotcrete. Do you think it's a lazy thing for them to use rebound?
Was thinking there is coating I could use or something...just dont want trouble down the line!
bdavis466
Platinum Supporter
In The Industry
Aug 4, 2014
4,663
San Clemente, CA
Not 100% sure they did use rebound but it was mentioned above. The thought was that it was used in the spa.
I used a company out of OC called Dynamic Shotcrete.
I'm very familiar and have had good and bad experiences with them.
Rebound is not ideal and its use goes against best practices but it isn't nearly as big of an issue as it is with dry mix gunite. I bet 95%+ of the pools in Southern California were built in the same fashion that yours was and they are structurally sound.
bdavis466
Platinum Supporter
In The Industry
Aug 4, 2014
4,663
San Clemente, CA
Thanks for the reply. Reassuring for sure.
Do you think it makes sense to bother with a waterproofing agent in spa area or will plaster be ok?
The waterline tile should be waterproofed no matter what and I highly recommend a material like Basecrete for the entire pool.
debuda
46
Los Angeles
Oh man! More to think about and so many more questions now!! And I thought I was almost done!!
In terms of waterproofing tile line - We had them silicone the joint between coping and tile - Are you talking about another type of waterproofing for tile?
Basecrete looks like they have a few products that might be applicable - There is the Basecrete and Basecrete plus. Which would you recommend?
Would basecrete change the application of plaster at all? Should the plaster guys do this work?
Thanks!
bdavis466
Platinum Supporter
In The Industry
Aug 4, 2014
4,663
San Clemente, CA
The waterproofing should have been installed prior to installing the tile.
The standard version would be fine and just about anyone can install it.
