New pool build - Owner-builder
debuda
83
Los Angeles
Hi everyone,
I'm just posting my pool build so far. We are in the LA area. Decided on a 16x40 pool with a 6" raised spa (7x7).
For pool equipment we went with Pentair for pumps (3 hp VS, 1 hp booster pump), cartridge filter, heater (400k), and control center (easytouch 8).
Plumbing: Pool and spa circulation plumbing: (3) return lines on 2.5” line, vacuum line 1.5” line, 2 skimmers on 3” line, spa suction on 2.5” , and spa return on 2.0”, 3/4” fill line for intelli level
So far we have completed the excavation, rebar, rough plumbing and electrical and shotcrete. We are going to start next week with the pool deck and coping. Once we pass inspection there its on to tile, finish plumbing and electrical, installing gates and finally plaster!!
Hope we can get through the rest in the next month or so. We would love to have the pool opened for Summer.
Here are some pics of the build so far....
debuda
83
Los Angeles
Hi,
Not too sure yet about colors. Have been looking at This tile. We are going for mini pebble but also not 100% about color. We like the water a little deeper blue. Any suggestions welcome!
kimkats
41,273
Tallahassee, FL
LOVE, LOVE, LOVE that tile right there!!! That will be so pretty!
Plaster color--------the darker you go the more prone to mottling it may be. Just something to think about. Here is a thread that was started to share different plaster colors. This might help you:
Kim:kim:
debuda
83
Los Angeles
Kim:kim:
We hope it all comes together in the end. So many option and styles.
Thanks for the link!
You think pebble is still prone to mottling. One of the reasons we want pebble is to prevent mottling.
kimkats
41,273
Tallahassee, FL
Reactions: chemillion
debuda
83
Los Angeles
I have a set of links to help you get the best plaster possible. It is a lot of info but worth looking over.
Ten Guidelines for Quality Pool Plaster Best one of all
All Plaster Finishes Should Last 20 Years
Not All Color Pigments are Good for Pools How to pick a good color for plaster.
A Plastering 'Watch List' | Professional Watershaping | Watershapes
Trouble Free Pool
Trouble Free Pool
Any plaster can mottle. It all comes down to the crews skills, experience, care, etc.
Kim:kim:
Thanks for all that info!
Hoping my plaster guy knows what he's doing!
debuda
83
Los Angeles
Another pic for now with coping and tile in.
We have deck coming pour tomorrow.
We decided on this tile in the end.
Hope the decking and coping work out together. Coping we chose the Davis color Outback and we are installing Mocha for the decking.
Will post picks once it's all cured.
We're have gates inspection next.
Any thoughts on fencing? We are looking at a 5' high mesh fence vs a metal (aluminum or iron) fence.
kimkats
41,273
Tallahassee, FL
That tiling and coping came out GREAT! I LOVE the tile you picked out!!! PRETTY!!
Make sure they put some kind of "chair" under the wire to hold it up. Do NOT let them pour unless they are there. They may try to say "We will hold it up as it is poured"!! It will sink back down when they let it go :( If it stays on the bottom like that it will not do any good for your decking.
Kim:kim:
bdavis466
Platinum Supporter
Aug 4, 2014
5,015
San Clemente, CA
That looks great!!!
The filter does not need to be bolted down. I don't THINK the heater does not need to but will call in someone who will know for sure. @bdavis466
Kim:kim:
Honestly I don't think it needs to be bolted down but I failed a final inspection because of that. I would imagine the inspectors are quite particular in LA...
debuda
83
Los Angeles
That looks great!!!
Kim:kim:
Thanks!! Excited seeing it all come together!!
And thanks for the call out.
Pool build is looking great! Looks similar to our build but yours is going much faster. I like the color of the coping you selected.
Thank you! We spent many months planning and we really moved in the beginning but slowed down after we had the shotcrete placed because I didnt line up any subs for the finish work. It's been about three months in total.
debuda
83
Los Angeles
With the earthquakes and all they are very particular especially when it comes to gas appliances.
I didnt even see a place to bolt down the heater.
One thing I brought to the attention of the plumber was that he installed the gas line before the earthquake gas shutoff valve. He told me that as long as its outside it's no problem (that still doesnt give me any peace of mind!).
I guess I'll find out when they come to inspect but would live to pass on the first go round.
debuda
83
Los Angeles
Didnt really look at this picture before... your right it does look very similar! I like the sun shelf you put in. And the pavers look awesome!
Reactions: OGSW20
OGSW20
120
San Jose, CA
Same here, everything went quick until after the gunite was finished. Then all the tile, masonry, and paver work seems to be dragging on and on. Many LONG breaks from 1-2 weeks at a time. In June, they worked 6 out of 20 workable days. They finally came today to work! Suppose to be here all week. We’ll see how much gets done before the next long break.
debuda
83
Los Angeles
Looks like you dont have too much more to go. Hope they will get it done this month!! What kind of plaster are you going with?
