Question: I've read here often about hanging the sock in front of a return, away from the side. Why don't we put a CYA sock in the skimmer basket? Wouldn't that be easier, safer?
It isn't a problem putting it in the skimmer *as long as you keep your pump running until entirely dissolved*. If you let it sit there with the pump off, the acidic cya will cause the standing skimmer water to get very acidic. Then when you turn your pump back on you're giving your pump gaskets, etc a huge bolus of acidic water. Not so good for equipment in the long run, y'know?
Maddie
![Flower :flower: :flower:](/images/smilies/icon_flower.gif)
