S L O W Chlorine Build Up - And A Question
In the morning of January 29th. one of the crew added 4 Tri-Chlor Tabs to the Pentair inline chlorinator.
I have run the pump almost 24/7 since then but at varying speeds.
Chlorinator has been set at Max most of the time since then.
I have only used the Safety Test in the TF-100 kit so far but the Chlorine has been very very slow to
come up.
Here is what I am seeing:
Evening of 1/29 - no trace
Morning of 1/30 - no trace
Evening of 1/30 - no trace
Morning of 1/31 - no trace
I cut the pump and opened up the chlorinator and the water did drain into the pipes.
I then turned the pump on a lower setting and saw that water was not entering the chlorinator.
I then bumped it up to a medium setting and was able to fill the tube. I re-capped the chlorinator once
the water was at the very tip-top of the tube and let the pump run on a higher speed all night long.
I bumped the speed up even higher this morning and then took a test a bit later.
I got a slight color change but not even yellow enough to call it .5.
I then ran the pump on that setting for the rest of the day and by this evening
I finally got to .5
Of course I was concerned about the slow build up (the pool has been full for a week now) - so after sunset I went to Pool Math and dialed in my current numbers and decided to simply add 1 gallon of 10% liquid chlorine. So now I know I have at least some decent level in the pool for certain.
So in the morning I will check my level again.
Now my question - should I simply turn off the in-line feeder off and begin to manage everything manually for now?
I am shy about adding CYA. Advice most welcome here. How fast should I introduce it?
I don't want to overdo it but I really want to move from Tabs to liquid anyway ASAP and then, once things are in a decent range, begin to use my Stenner pump for permanent chlorination.
This image makes me think of how very in the dark I have been and how much all of you good people at TFP have kept "enlightening" me. Thanks!!!!
Pretty nice - eh???
